Helimax This is for all your Helimax questions and comments.
Plastic blades
Old 06-08-2007 | 01:22 PM
Default Plastic blades
Has anyone found or tried plastic blades for the axe yet?
Old 06-08-2007 | 02:53 PM
Heliko's Avatar
Default RE: Plastic blades
I have [link=http://www2.towerhobbies.com/cgi-bin/WTI0091P?&C=EEA&V=JCH]JCS blades[/link] from Tower. They work great.
Old 06-08-2007 | 03:42 PM
I also have the JCS Blades. And they do fly good.
Old 06-08-2007 | 04:28 PM
i am assuming these are more resistant that the blades the heli came with?????
Old 06-08-2007 | 11:11 PM
more resistant to breaking, yes, but less resistant to causing more damage =P
on the cpp if you do the paper clip sheer pin mod then it really reduces alot of the negative aspects
Old 06-09-2007 | 12:51 PM
What is the paper clip sheer pin or should i just stay with wood the break easy I now i did it last night. I am new to heils but man was that fun. I have flown a lot of rc plane but this is dif. but i will get this soon i did good untli i used thr. up.
Old 06-09-2007 | 05:10 PM
I have a set of plastic blades. They do work OK. The only drawback is in a hard landing they tend to hit the tail boom and brake blade grips. Blade grips are easy to replace and the tail boom will bend back.
Old 06-13-2007 | 07:38 AM
I've noticed with the plastice JCS blades that when in a stable hover about 4 to 5 ft off the ground she will all of a sudden pull up and climb 10 to 20 ft more on its own. RPM's holding stedy. I've even tighten up the bar in the radio to make sure it was not me causing it while working the tail. Anyone else having this prob?
Old 06-13-2007 | 07:22 PM
ORIGINAL: tigger_roo
musta missed this post
here are the instructions I made up for the cp pro
http://www.heli-max.net/mediawiki/in..._Sheer_Pin_Mod
Old 06-13-2007 | 10:27 PM
Isn't that called the "Jesus bolt"?
Old 06-13-2007 | 11:38 PM
sure is =)
