Helimax This is for all your Helimax questions and comments.
Rotofly EX
Old 06-09-2007 | 06:26 PM
mp_gohl's Avatar
Default Rotofly EX
Need help, bought a rotofly and i don't think is all there. i can get the lil blades to tilt when i push the right stick up and down but when i get to moving the stick left and right NADA.. not sure if there is supposed to be something connected and its missing, and is the only thing holding the main blades on, the two little control links ?? does anyone have a good idea on what the heck is happening ????
Old 06-10-2007 | 04:17 AM
Default RE: Rotofly EX
I would double check that the servo's are hooked up and hooked up to the right channel. i don't really know anything about that heli though. You might try contacting the vendor or the mfg if no one here can give you some good advice.
Old 06-12-2007 | 05:16 PM
Well, I had the same problem I think. Mine came without a linkage, as in it was missing one. So when I trind to fly it, no matter how hard I tried it would go backwards. Have you tried flying it yet? If it goes to one was uncontrollably, then your's is probably missing one of these http://www2.towerhobbies.com/cgi-bin...?&I=LXHPU3&P=7
Your roto should have two of these. Side note, the roto is fun little heli to me, for 2 mins before the motor gets to hot and looses power. Pretty soon when you learn how to control your heli good you will want a brushless motor, don't even try to get a replacement motor. on rcgroups there is a huge thread about this little heli, about 80 somein pages. There is some good stuff in there. Be carful though, you will get hooked on "Helicrack" quick!
Jacob
