axe cp both motor problem
CA
A couple of things you might want to check:
>>Before turning on your transmitter, make sure your Idle Up switch is off.
>>Check your connections between the board and the motor(s).
Do both of these check out?
CA
If it's still under warranty and you still have your receipt you can call up Heli-Max to get a free replacement. There are more than a handful of accounts of easily getting replacement parts for free, no questions asked.
