Charging A Electrifly LIPo Battery
NV
First I would like to thank all for the replies on my AXE CP drifting left,been windy in Las Vegas last couple of days so couldn't fly. I bought the ElectriFly Lipo Battery 11.1 v 910 mAh and the
ElectriFly Poly Charge LIPo Charger. It has 3 adjustment to charge at 250, 500, and 1000 mA
What level should I usr with this battery so not to ruin battery or charger
CA
You go with the closest setting to the battery so in this case the 1000 mAh setting. Does that charger balance the packs? If not you better get a balancer to go between the bat and charger or they won't last long.
TX
slotdr
If you go with the highest setting, you had better keep a close eye on the packs so that you don't boil them. I've had my charger on 500. And yes, you need a balancer before you try charging.
I went with the electrifly equinox. It doesn't cost much and it does a good job of balancing the cells. If you go with the equinox, you may need to modify the connectors that go from the charger to the balancer. I went ahead and wired in a 110 AC to 12.6 DC converter to the charger as well.
Ted
Ted
NV
Thanks, Another 30 bucks for a electrifly equinox, now I have a Power supply then connect the balancer then the battery is that correct??, I have the connector GPMM 3127 so I can hook it to the Heli. If anyone has this scenario what connectors do I need to accomplish this
MD
OK, slow down a minute-- does your PolyCharge have the same red JST charge connector that mine did? Does the battery have a balance connector? If the answer is yes on both, then you'll have to make some wiring changes to the PC to connect the Equinox, either by putting female banana connectors on it or by splicing the Equinox directly to it (OTOH, if you got the PolyCharge 4, it already has banana jacks).
If your battery does not have a balancing plug (a second plug in addition to the one that connects to the heli that is white and has four conductors) then don't waste your money on the Equinox-- it won't connect.
If you do have a balancing connector on the battery and you do get the Equinox, then you'll connect the PolyCharge to the power supply with the alligator clips, connect the Equinox to the PolyCharge, and then plug the battery to the Equinox using the 3S pigtail that came with the Equinox.
Simple, you will need an equinox. It can balance more than just your axe cp lipo. It can balance up to five cells. It already comes with the correct adapter for the two and three cell lipo packs from electrifly.
One thing though, you will have to put female bananna jacks onto the charger. I have made a jack with a mating jst plug for my charger, so that I don't have to use another connector for jst packs.
NV
OK I think I understand, is this where I put the the female banana,I circled it and if so the wire gage is different
TX
I just grabbed a couple of water proof automotive plugs. Not the bullet or crimp on type. Actual plugs. I then used a different style of plug for connecting the 110 AC to 12 DC converter to the lipo charger. This way I won't ever get them mixed up . It works out great and I can still connect my lipo charger to a car battery if I want. The whole thing may cost as much as 5 bucks for the connectors and another 15 to 20 for the converter.
I'll see if I can snap off some pictures this weekend and attach them.
Ted
Ted
