Battery Question
AB, CANADA
Hi, I have an Axe CP and was wanting to upgrade the battery. I saw this (Great Planes LiPo 11.1V 910mAh 15C) on Towerhobbies and was wondering if it is worth it. The stock batteries just aren't doing it for me anymore! If i get these batteries or similar is there anything I need to do to install them? I can hover pretty good now, so I need more flight time. Anyways, thanks alot.
should be pretty close, but likely you're gona want something more around 1300mAh or so. the 15C rating is good because you'll need something around that much for this size of battery with this heli. You can always go higher with the C rating if it's not too much money, but stay atleast 15 or better
TX
JoDyo,
I put together a listing of parts and battery packs for the AXE CP. If you send me your email, I'll forward the list to you.
You will need to get a micro Deans to ultra deans connector/adapter to use the electrifly BP910 Lipo pack. Most of the other packs either come with the ultra Deans connector or you have to solder the connector on yourself. You should call and ask if you need any special plugs to use a particular battery pack.
Ted
Ted
