Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Setting up a Helimax MX 400 Pro >
Helimax This is for all your Helimax questions and comments.
Old 03-30-2008 | 12:07 PM
My Feedback: (9)
Default Setting up a Helimax MX 400 Pro
I purchased a MX 400 Pro for my Son for Christmas. He has flown several Dragonflies and Honey Bees successfully. He is having problems setting up the gyro and programming his Hitec Eclipse 7 Radio.
Because I fly RC planes and run boats, I'm unable to help him and no one else in the area flies helis.
We would both appreciate your help. Thanks alot.
Old 03-30-2008 | 02:23 PM
Default RE: Setting up a Helimax MX 400 Pro
Several months ago I asked a similar question and Airman Bob sent me these settings which worked very well to get me going. I have a different radio than you so I can't help with those specifics but these are the curves that I began with. The one change that I have utilized is to make my Normal Throttle look more like an Idol up throttle in order to prepare me for when I enablethe Idol up later when I get better. I am using 0, 65, 65, 65, 65 This seems more steady as only the pitch is changingt. Good Luck from one Newbe to another. Cheers
Try these settings:
Well, if you're Pro looks anything like my Pro you don't use 3-S as your swash setting. You MUST use 1-S.
The transmitter settings should be like this:
RevR screen:
chan 1 nor
chan 2 nor
chan 3 nor
chan 4 rev
chan 5 nor
chan 6 nor
D/R
chan 1 100%
chan 2 100%
chan 3 100%
chan 4 100%
EXPO
chan 1 0%
chan 2 0%
chan 4 0%
EPA
chan 1 70%
chan 2 40%
chan 3 100%
chan 4 60%
chan 5 100%
chan 6 35%
TRIM
all chan at 0% to start out (will change when you fly and trim)
N-TH
1 - 0%
2 - 50%
3 - 70%
4 - 85%
5 - 90%
N-PI
1 - 10%
2 - 30%
3 - 50%
4 - 50%
5 - 68%
I-TH (idle up throttle)
INH (inhibit this while learning or face disaster)trust me on that.
I-PI
Blank
HOLD
0% (set a zero so that if you bump the THHOLD switch by accident you don't go to a high throttle setting. With this switch in the forward position (towards you), your throttle stick will not work).
REVO
INH (don't use with a heading hold gyro)
GYRO
INH (if you have an inflight adjustable gyro then you use this to switch between Heading Hold and Rate gyro.
SWSH
1-S You MUST use this setting if yours is mCCPM like mine. Check the photo and see servo positions. If they are same as mine use 1-S only.
NOTE: These are all settings that will get you up and hovering when your throttle hits about the 50% position. Later, when your hovering well you may want to experiment with these settings. Be SURE to write all these down BEFORE you go changing anything.
Bob
Old 03-30-2008 | 07:17 PM
Hmmm, another thing you might want to do is buy or borrow a Castle Link . These cost about $30 and conect the ESC directly to a computer to allow you to see and change the settings. You can do this without the computer but it is very difficult and it is quite easy to accidently change settings because you have inadvertantly entered programing mode.
Old 12-15-2008 | 12:51 PM
I have a mx pro in a box right now....
I also have in on my realflight sim....
Is this a accurate depiction of how this helicopter is????
In the sim it needs much more power with 3s lipo packs..... It has a hard time just pulling a loop...
How does the real one's fly???
It seemes that to do anything but hoving and strait flying is all it's capable of...
3D-just seems posiible only with a motor upgrad (in the sim anyway)
Is this true??
Old 12-15-2008 | 07:58 PM
jw637362's Avatar
ORIGINAL: kochj
Is this true??
Kochj - No this is not accurate - the MX400 flies well out of the box, Stock motor Helimax - 3S lipo, it is what I learned to fly helis with. Will go inverted and hold hover.
On another note though. I would NOT recommend the stock configuration for this heli. Upgrades are very important. The Motor and SC overheat. Causing more problems then you can imagine inthe long run.
Change the Rotors as well.
Rehabber - It is a great little heli and can be a great one to learn on. Take the advise I gave Kochj - Upgrade the motor and SC, youll overheat your batteries and the speedcontroller is not sufficient. I modified and installed a large Heat sink on my motor and SC. Sorry I cannot assist with the Radio stuff though as I use a RD6000 airtronics. BTW, What Gyro you go with. I use the Futaba GY240. Works fine.
In addition, Check out My thread on this Heli - Mx-400 purchase sorry, just search for it, dont know how to link it.
Old 12-15-2008 | 11:36 PM
ohh man....
The stock configuration overheats????
The reason I went with that one and not the mx450sx, was because it came with that stuff.....
It is -10F here right now, so if I fly outside and its like 20F I should still be okay.... shouldn't have to worry about it then
