Where to connect the orange wire
What i have
AXE CP
GY401 with the c12 ESC
dx7 with AR6000
Here are the connections:
1. BAT port - not connected
2. THR - connected to ESC/3 in 1
3. AILE - connected to Right Rear Servo
4. ELE - connected to Front Center Servo
5. RUD - Connected to Gyro
6. GER - Connected to Gyros sensitivity switch (yellow wire)
7. AUX - connected to Left Rear Servo
With all of this installed I have no place to connect the orange wire from the 3 in 1 and
i don't really know what it is used for. Does anyone know were I should connect this wire and if
i need to connect it?
Thanks in advance!
AXE CP
dx7 with AR6000
Thanks in advance!
FL
The orange wire was the tail motor ESC input for the 3 in 1.
It is not needed in this configuration. You can stow it or remove it.
Your choice.
Your choice.
