Axe CP not responding to transmitter
My Feedback: (41)
I flew my Axe CP last night with no problems. When I got up this morning I charged the battery and connected it to the heli. When I connected it to the heli the servos did not center and it will not respond to the transmitter. Does this sound like a problem with the receiver or the 3in1 board. Is there any way to check each of the boards. The heli has only been flown 10 or 12 times and hasnt received any damage to the electronics. I tried using another battery with the same results. The servos will move when the battery is first plugged in but as stated before they do not center and will not respond. Could there be a problem with the transmitter it has never been dropped or anything. Please help.
GA
ORIGINAL: kbailey45
I flew my Axe CP last night with no problems. When I got up this morning I charged the battery and connected it to the heli. When I connected it to the heli the servos did not center and it will not respond to the transmitter. Does this sound like a problem with the receiver or the 3in1 board. Is there any way to check each of the boards. The heli has only been flown 10 or 12 times and hasnt received any damage to the electronics. I tried using another battery with the same results. The servos will move when the battery is first plugged in but as stated before they do not center and will not respond. Could there be a problem with the transmitter it has never been dropped or anything. Please help. asap very worried
MI
Could be a problem with the batteries. Are you sure the transmitter is working? Make sure the crystal is in the receiver all the way. Beyond that, its anybody's guess.
My Feedback: (12)
IL
see if you can find a good reciever to swap it out with. If you have a car, I'd think that it would work with a crystal change enough to either eliminate or find your problem, verify this though, there may be some difference taht will keep them from working together..
