AXE 400
this week i ordered an axe 400 rx-ready and was wondering what if anybody had an comments on it. like flight caracteristics and is set-up going to be hard (i have a futaba fasst 7 ch.) ect. i have already mastered hovers and basic aerobatics w/ my bladecp. so please comment.
KS
I own an axe 400 rtr. I haven't had to set up the controller myself, so I probably couldn't help u more than if you just read the manual. The Axe is a great stable flier. The helicopter is smooth in flight and the parts are durable. Where it falls short is aerobatics. The gyro is great for forward flight in warm weather, but its performance begins to decline as it gets colder (mostly noticeable in below freezing temperatures). I've never tried it, but I hear that the gyro doesn't hold as well in backward flight. Other than that, it works really well. Another issue is the left piro rate; it's much too slow for my taste. That relates back to the gyro too. I suppose you could get larger tail rotor blades, and that would probably help. I've been meaning to do that, but I've just not gotten to it yet. I have a 25C battery, but I haven't flown it yet. I've noticed that batteries 20C and lower are just too underpowered to fuel precise aerobatic maneuvers. It's not that the heli can't fly inverted or do tic tocs,etc; I would just not attempt them at a low altitude. After I fly my 25c batt, I'll be able to determine if I need a more powerful motor or not. Other than those things mentioned, the Axe 400 is a great machine, and I'm sure you'll have a great experience with it. The parts are also very interchangeable with T-Rex and T-Rex clone parts. For example, I got an all metal rotor head for under $30 from hobby king. Anyway, good luck with setting up the radio. I hear that referring to the rtr manual might help if you can't find what you're looking for in the rxr manual.
KS
Yes, I am currently using the HK450 head. Works great. I didn't try to make their swashplate fit, because it didn't look like it was a good match for the frame, so I didn't even bother. I am still using the stock swash. I did notice though that the Exceed Genesis 450 V2 from XHeli has a replacement cnc swashplate that looks like it would fit the Axe 400. I haven't personally tried it, so I can't really comment on it, but it's only 13 bucks, so it might be worth a try. Here's the link
Hope this helps!
Hope this helps!
I am trying to find out who is the manufacturer of the AXE400, we know is not helimax. The head on the AXE400 resembles the one for the Razor450 by Daynam, the Razor swashplate is similar to the AXE400. There are better helis out there but I still like the AXE400.
The reason it would be interesting to know who is the manufacturer is that it may be possible to get the correct upgraded parts at a good price. And tower hobbies is not offering upgrade parts anyway.
I Just ordered a couple of swash plates for the E-Razor 450 from XHeli, they were $14ea, they look similar to the AXE400, but the main reason I order them was for my new Dragonus II from Hobby People, they have a sale on the kit for $40. So far I am very impress with the heli.
KS
So, I just want to take back what I said about the HM4000 gyro that comes with the AXE 400. Basically, it's awful. Don't bother with it. Right off the bat, get yourself a trustworthy gyro. I'm using the SKY500 from Skyartec, and I've had that gyro for a few years now, so I know it works. The HM4000 pretty much switches off on left piros. The left piro rate is slow from factory set up, because that slows down the rate at which the gyro quits monitoring the tail. When you speed up the piro rate, it becomes evident that left turns mean absolutely nothing to that gyro. It's a design flaw in the component. I had support send me another one, and shockingly enough, same problem. That's when I switched to my skyartec gyro.
Other than that awful gyro problem, the helicopter is great. I'm just disappointed that they would skimp on something as crucial as a gyro.
Anyway, keep on flying guys :-)
AZ
Lipo batteries do not like the cold at all. If you are flying in cold temperatures, keep your battery inside and warm as long as possible before flying. Also expect a shorter time when flying in cold temperatures.
KS
Well, I finally got up the nerve to hover my Axe 400! I didn't intend to... I was just going to check the trim, and the next thing I know, I'm a foot in the air, then two, and it's holding a hover and heading very nicely, so I kept at it till the battery ran down. Seems like the gyro is holding OK (read the PDF on adjusting the pot under the label and adjusted accordingly). It was great fun, and I'm glad I finally got a chance to give it a whirl (no pun intended). The practice flying square circuits with nose in, left, right, and tail in with the Mcx and mSR seem to be paying off in confidence.
That, and the Axe in Low Rate is really very newbie friendly. I tried a HBK3 and a Blade 400, and I have to say this one seems just right for my skill level.
Now, if I could just get the parts in for my SR and get that up and running again, I can continue to segue my way to some forward flight!
KS
ORIGINAL: OQUINN
So I totaled mine today, the whole head unit exploded
any body got any recommendations for a CNC head and tail unit, sorry I'm a newbie so I don't know the names
PS: You'll need either the original Axe 400 swashplate or I think the metal swashplate for the E-Razor (or Genesis...can't remember) from Xheli.com. I've never tried the metal swash from the Xheli helicopter, but it looks like it'll fit...you could always get both, and if the one from Xheli doesn't fit, then just put in the stock swash from helimax, cuz that's what I'm still using. Also, be sure to adjust the linkages to the washout arms (on the head assembly), because upon installation, they won't be set right. Both arms need to be level when your throttle is at 0%.
PS #2: As for a good tail assembly, you can check Xheli.com They have a head and tail combo (i'm pretty sure). I don't have any experience with that particualr product, so I can't say if that'll work or not. The head looks exactly like the one I got from HobbyKing. Since I crashed face-first, my tail is fine, so I don't really need one.
ORIGINAL: dragus359
Weird, I totaled mine earlier this week...must be a bad week for Axe 400's. I got too ballsy with my less-than-adequate 3D skills haha. Mine's pretty mangled :-(. Here's the head that I current'y have on my used-to-be bird: http://www.hobbyking.com/hobbycity/s...idProduct=9790. You'll be happy to know, that despite a full speed slamming into the ground (with a bounce), this rotor head stayed intact (except for the flybar, which tried to wrap itself around the head. Silly flybar.
ORIGINAL: OQUINN
KS
Oh wow. My condolences. You can also check out HobbyKing's models. I can't really suggest much, because I woudn't know which t-rex clone out there is the best. I considered getting a clone, but I think in the end that I'll probably end up rebuilding my Axe. I still have my old modded Axe CP in the meanwhile though
