helimax mx 400 pro
![](/forum/images/badges/trading_plus_member.png)
OH
Hello, I have never used the forums before. I'm having a problem with a helimax mx 400. I can't stop the tail from spinning counter clockwise. If there is any responses I will go into detail. Thanks John
KS
I don't know if it uses a belt or a torque tube, but whichever one it is, in addition to the suggestions above, you might want to double check that the belt or gears are working properly.
KS
Thanks :-). Oh and since it's a belt drive check the little pinion gear that's on the tail rotor shaft. Chances are that it's fine, but I cracked mine once in a freak accident lol. A crack can loosen it and cause it to slip on the shaft.
