Help?? Hitec / Futaba buddy boxes
ND
I have a Hitec flash 4. Can I use a Futaba buddy box and cord on this radio, or do I have to but a Hitec. We have Futaba buddy boxes all over the place.
razz423- Hitec and Futaba are trainer compatible. It is best if you use the Hitec cord to connect the two, but if you must use the Futaba cord make sure you remove the crystal from the slave or it will emit a signal.
Mike.
Mike.
