Hitec Aurora - problem with mixes
By using my Aurora I have tried to set this mixes:
1. mix:
Master: AILE1 (1.channel, control select J1)
Slave: AUX1 (8.channel, control select NULL)
Rate: L=+100%, R=+100%
it works good. If I move the stick J1, servo in 8. channel moves too.
Then: (copy from 8. channel to 9.channel 100%)
2.mix:
Master: AUX1 (8.channel, control select NULL)
Slave: AUX2 (9.channel, control select NULL)
But it does NOT work! NO copy from 8.channel to 9.channel. Sevo in 9. channel do not move like servo in 8. channel
Why is this impossible?
1. mix:
2.mix:
RE: Hitec Aurora - problem with mixes
ORIGINAL: mior
1. mix:
2.mix:
Why is this impossible? Thanks
1. mix:
2.mix:
Alan T.
