Optic 6 Throttle Setup
CA
Hi,
When I was using my Flash V throttle setup was easy:
Zero the trim
Set the carb to just closed
Set the idle with the trim - generally about 75 on the screen
It's not that easy on the Optic 6.
There are only 50 units of trim - not enough throw.
What is the proper/recommended way to set up the throttle linkage?
KW_Counter
Zero the trim
KW_Counter
RE: Optic 6 Throttle Setup
ORIGINAL: KW_Counter
Hi, When I was using my Flash V throttle setup was easy:
Zero the trim
Thanks, KW_Counter
Zero the trim
Thanks, KW_Counter
on page 11 of the tutorial found under:
. Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ
NB: Make sure that when setting up the Throttle Cut function that the servo is not stalled by forcing it beyond the limits of the throttle body on the engine or the pushrod ends. All movement by the servo should be easily accomplished without stalling the servo which may require experiementing a little with the holes on servo arm or throttle arm.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
CA
Alan,
Your response was not helpful at all.
The manual was not helpful either.
I am looking for a response similar to the example I used
when describing how I set the throttle on the Flash V.
Thanks for trying,
KW_Counter
Thanks for trying,
KW_Counter
Post # 66 may help you acheive what your looking for.
http://www.rcuniverse.com/forum/m_95..._3/key_/tm.htm
cheers
john
cheers
john
CA
Here is the method I am now using.
Set the trim to 25, the middle of the range.
Set the throttle mechanically so you have full range.
Start the engine.
Adjust your idle using the Sub Trim.
Now your idle trim can be used to fine tune the idle.
Make sure the engine kill button still works.
Good Luck,
KW_Counter
Start the engine.
Good Luck,
KW_Counter
