605 question
Mike
I was checking my ailerons on my Stinger 120 everything was good including range check.Started my Quadra 52 and the right aileron went to full deflection shut down everything was normal. Repeated 2 more times with same results.I am using 1 servo per aileron into a y connector. switched plugs in y connector same result.Futaba ends on the servo.
When I got home I pulled the servo and found the wires had been pinched and the black wire was 3/4 broke off right where it exits the case. I swapped the servo out with another 605 but haven't had a chance to test it yet but is it a good possibilty that it was my problem?
What is the cost to get a new end put on the servo if that is the causeof the problem.
Randy
Randy
