Flash 5 methodology - Mike ?
Mike
I'm trying to get clear in my mind an image of the functional block diagram of what happens in a Flash 4/5 radio.
This will help me understand why some functions happen to effect others the way they do.
Is this below about right ?
Starting at the sticks.
Stick input movement
then CPU Proccessing (in this order)
Per Servo EPA settings
then
Expo % proccessing
then
Channel Mix (if used, e.g. Elevon) proccessing
then
D/R selection proccessing
then
Servo movement output to TX module
Mike is this right ? Could you edit it. I'd like to draw it up as a block diagram and stick it in the back of my manual.
thanks
Martin
then
Expo % proccessing
then
then
then
thanks
Martin
