EVO Setting Problem or Product defect ??
Mike,
I bough the RoyalEvo (HFM-S, software 1.26, serial#1173880) from Tower on June.
Problem 1.
The four major stick's and two proportional switch movement (physical)
has almost 8% "DEAD ZONE" each on both end.
Such as the throttle has 28 click from top to bottom(1=top, 28= bottom),
servo move 100% from click 3~26 in the servo monitor & physical servo .
There is no further servo movement on click 1,2 , same on click 27,28.
All proportional control ,4 major stick + E & F
switch have same situation.
Problem 2.
Berg 5 receiver with JR DS8301 will has glitch when I use the Sync module.
I borrowed an fixed channel HFM-4 and the problem disappear.
Is it setting, version or physical problem??
Should I mail it back to Hitec???
I am very trouble on these problems, appreciate your response and advise.
DRMA
Problem 1.
Problem 2.
DRMA
I had a similar problem
it can be resolved with a little adjustment of the tension screws
Mine felt like there was a little more motion after the signal stopped changing.
after I adjusted the tensions a bit it got nice clear end points.
Ed Buell
Ed Buell
