Eclipse with glitches
My Feedback: (24)
FL
My Eclipse is having intermitent glitches on the aileron channel. Its hit or miss, I crashed one plane because of it. I thought at first i had a servo problem because it had got soaked with gas residue from the engine till I checked it on two other planes with the same results. If you knock the case you can cause it to work/not work. I checked for loose connections but didnt see any. I know I need to send it in but was just curious what could be the trouble? Also what is the turn around time right now for service? Its flying season an NO radio sucks[:@]
Thanks Dan
Thanks Dan
My Feedback: (31)
Sounds like a loose connection of some sort or another. Its difficult to make an astute observation on line. Return the your equipment to Hitec Service for a thorough check up...
Service and time info below:
http://hitecrcd.com/support_SFS.htm
