what Hitec Tx can work dual elevator servos?
My Feedback: (16)
TN
I am wanting the ability to use dual elevator servos on separate channels so I can adjust reverse, EPA, dual rate and expo on both servos. I also want both servos to be trimmed using the elevator trim, not just one. Is there a Hitec radio that can do all of this?
I also would like know if any Hitec radios have the ability to do low rate and expo simultaneously. I have the Flash 5 and have not figured out how to have low rate and also expo. I can only set it up with high rate and expo and low rate without expo.
RE: what Hitec Tx can work dual elevator servos?
[quote]ORIGINAL: AnthonyH
[/quote
From personal long use the older Prism 7X as well as the Eclipse 7 both provide for simultaneous use of dual rates and expo on rudder, elevator and aileron. I cannot address this on the Flash 5, or the new Optic 6.
Additionally different expo percentages can be used for hi or low rate on any given control surface.
John
[/quote
John
My Feedback: (16)
TN
So you are able to have expo on both high and low rates? With the Flash 5 if you switch one on you switch both on. eg. dual rate and expo are on the same switch.
ORIGINAL: AnthonyH
John
