Hitec Eclipse 7 problem
My Feedback: (15)
CA
Hi
I have a problem with my about 3 month old tx. 1st time that happened about month ago. Transmitter loosed a signal. NO control at all.
Then, i turned off a tx. turned back on. Worked great. Other signal lost happened today. Lost signal , no control. lost my at6.[
we check all connections on plane . nothing . all looks fine and everything works ok again. Is anyone had that problem?
or any idea, why that happens? I can send tx for checking , but this is a intermit. problem, probably they will found nothing.
Now, kind off scary to use that tx. i Don know when next signal lost will happen. If anyone has any advise, Please let me know.
Thx
]we check all connections on plane . nothing . all looks fine and everything works ok again. Is anyone had that problem?
Thx
WI
Don't Fly!!! I had that problem and it doesnt fix itself! In fact, it will get worse if it is the same problem I have. I will be getting mine looked at soon, hopefully cheap fix because I really like tx as well. Started as you described, but now no signal unless tx is held just so or I keep thumb or finger on antena. Sounds like a recurring problem to me.
CA
Hi PlaneRacer,
I have to agree with Matt G on this. If the radio is cutting out, don't fly with it until service has examined it. The best thing to do is send it in with a note describing the problem in as much detail as possible. Mention what you were doing when it cut out and how you brought it back.
