Hitec Eclipse 7 problem
MO
I have an Eclipse 7 transmitter. I had a cell go bad while charging at our field (Hitec 535 field charger) Since discovering the problem, the transmitter will not turn on. Is there a fuse that I can replace, or does the transmitter need to be sent to Hitec for service?
Thanks guys. You've all been very helpful
MO
Yes, I was charging through the transmitter. I will make arrangements to send it to the Hitec service department. I was just hoping that there was something I could do before sending it in
Thanks again
Thanks again
