Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 & 2 elev servos
Old 01-15-2005 | 09:34 AM
Default Optic 6 & 2 elev servos
I'd like to know if the Optic 6 will work with 2 elevator
servos in two different channels so they can be
matched. Thanks
Larry
Old 01-16-2005 | 12:50 PM
My Feedback: (31)
Default RE: Optic 6 & 2 elev servos
Yes, the Optic has a pre-defined mix for dual elevator servos with trims linked.
Old 01-23-2005 | 01:09 AM
Just picked up an Optic 6 for a P-51 with retracts and flaps, 2 ailrons, rudder, throttle, elevator. Thats 7 servos. World Models Instructions say 6-channel Radio. What's up? I don't see any way to Program ACGL to handle 7 servos. (I see 7 channel icons in the manual but can't see them on my DISPLAY..PROBABLY A MISPRINT??). I'm using a Supreme 8 Rx. Thanks from someone just jumping in the sport.
Old 01-23-2005 | 02:52 PM
My Feedback: (31)
ORIGINAL: lectronx
Flaps and ailerons are two channels, known as Flaperons. A six channel radio will work.
Old 01-27-2005 | 07:28 AM
aeajr's Avatar
ORIGINAL: lectronx
Counting channels, rather than servos, 2 ailerons, 1 rudder, 1 throttle and 1 elevator is 5 channels. Flaps go on the 6th channel. You Y cable the flaps if you want to use two servos.
Old 01-27-2005 | 07:34 AM
aeajr's Avatar
ORIGINAL: lectronx
On a 6 channel radio, you have two choices.
both ailerons on on 1 channel leaving a channel for retracts.
Or
Wire your retract servo to your flaps and put on a switch that takes flaps to a preset position. Flaps down, retracts down. Flaps up, retracts up. Then you can have ailerons on two channels.
Can't think of any other way to handle it.
Hope that helps.
