Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
digital servos
Old 10-15-2002 | 11:03 PM
Default digital servos
Mike, I fly exclusively hitec servos. Just getting into digitals and have been reading some threads/rants about excuses as why planes crash.
Not me.
I do need know I have a handful of 5645s with a modified july 2001 sticker on it. Does this need updating and I am going to buy a programmer, do all the new ones come with latest software.
ALso, if I ran my rcvr ant. thru about two inches of carbon fibre, will that screw things up.
Old 10-16-2002 | 01:17 AM
One more question. I have already soldered on extensions (about 2.5-3') worth. Any problems programming them with the extensions
Old 10-16-2002 | 03:22 PM
Thanks for not buying into the fear created by the vocal minority.
All the new programmers should be version 1.03, the latest.
Yes you should use the reset function on the July 01 servos
Version 1.03 also allows programming through extensions.
Best not to run the antenna "thru" carbon fiber if at all possible.
Old 10-16-2002 | 03:53 PM
Banned
The programmer manual says nothing about it however Mike Mayberry has made it known a few times not to reset them through extensions.
Old 10-16-2002 | 04:23 PM
The latest information we have here at Hitec is;
Programming thru extensions with the latest version 1.03 servos and a programmer is acceptable and appears to be working well in all the testing we have done. If anyone out there is having trouble programming through extensions, please advise Hitec of this issue.
Old 10-16-2002 | 08:57 PM
Banned
Thanks Glen, at one time Mike had said not to program them through an extension. Glad to know that this doesn't effect the programming after all.
Old 10-16-2002 | 09:09 PM
I just go my programmer updated with version 1.03 software. I have a bunch of 5625MG servos that I will be using in a new plane. I'm glad to hear that programming through extensions is acceptable (I probably will not do this any time soon - but you never know when it might come in handy). Thanks for the update.
Moses
Old 10-16-2002 | 09:38 PM
I too was very concerned about programming thru extensions as most users would have servos installed and many hard wire their installations making it really difficult to remove 'em. Just recently we finished a test series and proved the extension issue was solved. Yahoo.
Old 10-19-2002 | 04:36 AM
WreckRman2,
Now wait a minute...your not still using hitec digitals are you??? There had only be JR or Futaba servos in your planes! :boxing:
