Electron at 4.8V
I just got my new receiver electron micro which I plan to use with HitecHS 81MG servos
I read in the box it says to run a 3.0v so Ignore whether it would be a problem to use 4.8 battery since the HS 81MG need to run at 4.8V
Thanks in advance for the attention paid
OMar
OMar
Are you sure that's not 3.0V minimum? I've used Electron with a 4.8V battery pack and HS81s with not problems. The Electron is the 555 replacement which was always a 4.8V Rx to the best of my knowledge.
John C
John C
