Eclipse w/Spectra questions...???
I am thinking about replacing my current inventory of Transmitters;
1. Futaba Skysport 4
2. JR-431ex
3. JR 622's (2)
4. Airtronics 6 ch (ppm/pcm)
5. Jr 400
6. Hitek Focus 6
with a new Eclipse w/Spectra Module.
The JR's are a different shift than the Hitek/Futaba/Airtronics receiver. I see the Eclipse allows for both shift types.
Is that info (shift type) stored with the various model memory?
i.e. I select Ultimate 1.20 model from the memory, and the Transmitter already know that it is either pos/neg shift? Then I asume I just pull out the Spectra module and dial in the appropriate frequency?
Is there a memory upgrade for more than 7 models?
The Futaba receiver is an FM 7-channel, JR's are all R600's, and the Hitec is whatever came with the Focus 6. All are various frequencies, and the Airtronics is a PCM, (pretty old one).
Will the Eclipse with the Spectra work with all of these?
2. JR-431ex
3. JR 622's (2)
5. Jr 400
6. Hitek Focus 6
CA
The Eclipse will work with all your receivers except the PCM product.
There is no memory upgrade and no plans for one.
The shift select is per memory so it does "store" it.
Good Luck,
Glen Merritt
Hitec USA
Good Luck,
Glen Merritt
Hitec USA
