Hi mike, PRISM7
Hi mike, PRISM7
It looks like I am the first guy in the word trying to connect a PRISM7 to a PC , does HITEC have a feeling about that ?
No related document on the internet , nobody answering to post in forums ? :disappoin
Thanks in advance.
Thanks in advance.
Hi mike, PRISM7
Mike, If you give a look to this page:
http://www.leweng.com/support.html
You will see that the prism7 seems to be supported, and according to the documentation "Nearly any modern PPM capable transmitter with a trainer port can be used with RCJOY", does this means that some Prism7 models (not 7X) had been equiped with a trainer port (slave only ?) ? or is it a mistake ?
Thanks in advance,
-- FRI --
Thanks in advance,
-- FRI --
Hi mike, PRISM7
I just build this weekend the PPM2PC interface from Eric Brouwer and it works fine with my old PRISM 7 (not buddy socket) and FMS simulator using the "Serial PIC interface".
That's great !!!
I have used a pic16f876 and I am waiting for digital potentiometers (MAX DS1803) in order to test it with other simulators.
You can find the documentations and schematics for the PPM2PC interface at :
http://myweb.absa.co.za/eric.brouwer/interface.htm
:thumbup: :thumbup:
Here is a PRISM 7 connection scheme (you have to remove the HF module):
That's great !!!
:thumbup: :thumbup:
