eclipce problem
hi there i have a mazor problem with my Eclipce. i made a mistake and plag the battery pack in the wrong way ,+to- ant the oposite then i swiched the transmiter on ...nothing hapened and i saw my mistake so i pluged it ok and it was fine . the next day at the club i faound that all the chanels where reversed and the trotlle trim and cut didnt work .....then i reversed them all at the correct side and trim my model again but landed becouse i needed more aileron trim than i could have what do you think i must do ..........
CA
Hello,
What was the voltage at the time that you turned it on? If it was about 15 volts you may have done some damage to the transmitter that you would not be able to repair on your own.
I would suggest contacting a distributor in your area that would be able to help you with this. Below I provided a link with a list of distributors. Please locate the one in Greece or near you for assistance.
http://www.hitecrcd.com/pages/contact_us/86
