trim changes on high rate
I have an older Flash 5 radio that I am running on a profile 3d plane. When I go to high rate, the trim changes on the ailerons. I reset the radio to factory settings but when I set the low rate percentage (it's set at 60%) I get the trim change when going to high rate. I am using HS-635 HB servos on the ailerons. I am not experiencing this trim change on the elevator when I go to high rate. Any help would be appreciated.
