Multiplex battery monitor problem
AZ
I recently purchased a Multiplex Evo 12.
On the basic menu the battery monitor reads 0 volts. I removed the battery after an overnight charge and measured the voltage. It is 8.4 volts.
Since the battery reads 0 V on the monitor the RF will not come on.
Is there something in the programming that will cause this or do I need to send the radio in for service?
