Batt Size??
IL
Batt Size??
On a new airplane I'm using 6 servos one 422 one 5645 and four 5625, what size battery do i need will a 6V Nimh 2500 work for 4-5 flight 10-15 min each? or I need more, is there any site i can go and look at the current draw for these servos? thx SR
CA
RE: Batt Size??
The spec sheet for each servo on our website will show you running current but you need to figure out what your current consumption is with the loads you are putting on the servo to really find out if that is enough capacity for that many flights of those target times.
