Eclipse 7 and Elevon Dual Rates ?
AB, CANADA
How do you adjust/set the elevon dual rates on an Eclipe 7 ?
The D/R toggle on the elevator and aileron seems to not change the throws.
Thanks in advance.
Thanks in advance.
Go into the DR setting in the menu and set the travel in each switch position. I typically set 100% for the high rate (switch up) and 65% for the low (switch down.) Then I turn on the flight condition #3 and set everything to 125% for a 3D or "Max" rate.
Again... everything is set in the DR menu and sets the rate according to the switch position or flight condition. The same goes for expo.
Mike.
Mike.
