Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Eclipse 7 problem
Old 08-08-2008 | 02:38 AM
g-rock's Avatar
Default Eclipse 7 problem
HI,
Tuesday morning, I plugged in an aftermarket battery for my Eclipse 7 FM Spectra Module and Transmitter and I forgot to check to see if the polarity was correct before I turned on the transmitter. Obviously, it no longer works. I am pretty sure that the Spectra Module is OK for I tried it in my second Eclipse 7 FM Transmitter but I did not check to see if the RF was working. The LCD screen on the second transmitter seemed OK.
I would like to send it back for repair and need to know if you will also need the module and a battery pack. The transmitter is about 2 years old and I now longer have the original shipping container nor the receipt. I Purchased it from BP Hobbies. Can you also give me an idea of what this repair is going to cost? Thanks.
Gene Rock
Thanks, this message has been answered with an email.
Gene
Old 08-11-2008 | 03:06 PM
MikeMayberry's Avatar
Default RE: Eclipse 7 problem
It depends on the extent of the damage... $25-$50.
Mike.
