Throtle Servo Problem
Hello I am Having a problem with a throttle servo im using model # HS 475HB
What it is doing is it will work fine for a few mins, then it will just go to the stop posistion kind of like a fail safe engageing i have used a failsafe and bypassed the failsafe but it still after a few mins just stops responding and goes in to the stop posision. Any ideas? Also Note This servo is pritty much new i got it a while ago when i was rebuilding my truck... this was around 6 months ago now and hasent bin used sence becouse my motor was blown and i have slowly been rebuilding my truck. Also another note, the stereing servo still works wial the throtle one wont
Recever HFS-03MM
Servo HS 975HB Deluxe
Radio Agresser SRX
Recever HFS-03MM
Radio Agresser SRX
I would suggest you send it in to have it checked out.
While the 475HB is a upgrade from a standard servo is still lacks the power needed, in my opinion, to handle the Thottle/Brake duties of a Savage truck. The minimum I would suggest is a 645MG.
Mike.
Mike.
