Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
7985MG degree of rotation
Old 01-04-2009 | 02:09 PM
Default 7985MG degree of rotation
Does the stock 7985 servo come with 90 deg. rotation out of the box and to achieve 180 deg. you must program with one of the Hitec programmers ? I've read that you don't need the programmer to use them, but if they only rotate 90 deg. then that would not be sufficient on most applications.
Old 01-07-2009 | 04:19 PM
MikeMayberry's Avatar
Default RE: 7985MG degree of rotation
You can get up to 120 degrees of travel with your radio set to it's maximum D/R and EPA settings which is normal for all servos. If you program the 7XXX series servos past there default settings you can get up to 180 degrees but lose the higher resolution capability.
You should have no problem getting the desired control surface travel with the default end points. If you need more travel at the control surface then you will need to use a longer horn which is perfectly acceptable.
These servos offer the same travel as all other manufacturers so I'm not sure how you can say that it would not be sufficient on most applications.
Mike.
Old 01-07-2009 | 08:40 PM
Mike - Thanks for your reply. I think I said 90 deg. would be a problem. But you just said that they travel 120 deg. So that is what I find acceptable in most applications. Looks like I will be buying 5 of these babies.
