Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
eclipse 7 timer
Old 01-27-2009 | 04:21 PM
Default eclipse 7 timer
When the radio is on, there is a timer that shows 'how long'. What is the max time it will show and does it re-set itself when reaching this point ?
I was cycling my new (larger capacity) battery and noticed this. The first time ,I looked at the timer it was around 180 mins. Later, when I looked again, it was arond 30 mins ?
Thanks in advance for any info.
Old 01-28-2009 | 01:05 PM
Default RE: eclipse 7 timer
My Optic 6 will go to 200 minutes and then reset. I wish it would go longer because I get more than 200 minutes with the 2000 mAh Rayovac Hybrids I put in before I have to recharge them. I've given up on the timer for battery run time and just use it as another flight timer. I just go by battery voltage now.
