Flash 5 and flaperons
Larry,
I set mine up pretty much as instructed in the manual. The hard part (or so it seemed at the time) involved setting up the receiver. I was using the five channel 555 receiver. In that case you would need to connect one aileron servo to channel 1 and the other to channel 5 (reversing the servo as needed). The battery also uses the 5th slot on the 555, so you'd need to connect it via a Y-harness. Once I figured out that I needed the Y-harness it wasn't hard at all.
Hope that helps.
Doug
Hope that helps.
Doug
