Prism 7X Program
VA
Hello Mike,
I have a prism 7X that will not save program settings, also it will not allow me to select a model, the cursor will not move to 2 or 3. When I try a reset +&- key I get a short chirp not the double beep.In main edit mode i can make changes but they are not saved when the radio is powered down. swapped the battery with my prism 7 still no joy. The radio functions normally otherwise. both radios have not bin used for almost 2 years the prism7 came back to life normally, the 7X was not so Lucky. Any thing I can try? Or should I send in for repair?
Thanks. Joe Tuttle
Thanks. Joe Tuttle
