Eclipse 7 question
Hi, I have an Eclipse 7 and need some help. I'm wiring a P51 with flaps and retracts. Do I have the channel line up correct?
1. right aileron 2. rudder 3. engine 4. elevator 5. retracts 6. left aileron 7. flaps My second question is can I control the flaps with either the channel 7 switch or the flight mode switch vs. the VR 2 knob? What I'm wanting to do is have it set on the 3 position switch to have them set at full up, 15% down and full down? Is this possible with the Eclipse? If not then what about with the Optic 6? |
RE: Eclipse 7 question
ORIGINAL: cruzomatic Hi, I have an Eclipse 7 and need some help. I'm wiring a P51 with flaps and retracts. Do I have the channel line up correct? 1. right aileron 2. rudder 3. engine 4. elevator 5. retracts 6. left aileron 7. flaps My second question is can I control the flaps with either the channel 7 switch or the flight mode switch vs. the VR 2 knob? What I'm wanting to do is have it set on the 3 position switch to have them set at full up, 15% down and full down? Is this possible with the Eclipse? If not then what about with the Optic 6? |
But what I want is to control the flaps with the land 3 position switch? Is that possible?
Please note the flaps are control by a single servo. |
No, it is not possible. Only the VR2 or the channel 7 switch will control it.
| All times are GMT -8. The time now is 06:40 AM. |
