RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   Eclipse challenge (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/2989255-eclipse-challenge.html)
iamrandy 05-18-2005 11:10 PM
Eclipse challenge
Hello,
i have figured out how to P mix my rudders with the nose gear, but when i want to use them for speed brakes ( both rudder servos movng in the opposite direction ), they both still move in the same direction.
Help?
Thank You
mglavin 05-19-2005 09:42 AM
RE: Eclipse challenge
Please provide the programming steps you've utilized to effect the rudder mixes.
Off the top of my head I'd suggest you have to change the travel percentages ( + or - ) when the speed brake is deployed.
iamrandy 05-19-2005 10:18 AM
Channel 4 right rudder
Channel 6 nosewheel
Channel 7 left rudder
P mix # Master slave
1 4 6
2 4 7
3 5 4
4 5 7
as i said earlier, i do get rudders and nosewheel proper. when i wish to use the rudders for speed brakes, i would like the rudder servos to move opposite to each other.
again, Thank You for your assistance.
mglavin 05-20-2005 09:55 AM
I'll play with your set-up and see if I can figure it out... Give me a little time to get some gear on the bench and mock it all up.
iamrandy 05-20-2005 10:37 AM
Mike--
I can't ask for more than this. Thank You for your time and efforts. I am looking forward to seeing your results.
randy
mglavin 05-20-2005 01:14 PM
I was able to get it to work, se below for my set-up. You may require different values, but it proves it works.
pmix #4
L/U = 0%
R/U = +30%
pmix #3
L/U = 0%
R/U = -30%
To increase the travel speed brake/rudder, increase the percentages on both pmixes equally.
