RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   Eclipse 7 program--function from knob to switch? (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/6083774-eclipse-7-program-function-knob-switch.html)
ljsoarinson 07-08-2007 06:54 AM
For the Eclipse 7, a servo is plugged in to channel 7 and operates on a knob. How can I move that function to a switch and disable the knob?
Thanks!
MikeMayberry 07-09-2007 12:45 PM
RE: Eclipse 7 program--function from knob to switch?
A couple of options are to use channel #5 which is a switch or if you need to use channel #7 you can use the p-mix function and mix channel #7 to itself. This way when you flip the CH7 switch you will get whatever you have the knob set to. Be aware that typically you cannot get full travel using this method.
If you need help programming, you can always call us. (858) 748-6948
Mike.
