RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   hs 81 problems (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/965085-hs-81-problems.html)
crazhorse 07-17-2003 12:16 AM
hs 81 problems
I have a couple of Hs 81's that I changed to metal gears on, when I put the servo arms on at 90* turn on the radio and power to the rx and move the stick up on the radio the servo arm returns to 90, when I move the stick down and back to center the arm moves past 90 and stays there. I have tried it with 2 different receivers a berg and a futaba, and 2 different radios a 9C and a T6xhs. Anybody know what the problem could be?
MikeMayberry 07-17-2003 04:45 PM
hs 81 problems
Is this with nothing attached to them?
crazhorse 07-17-2003 04:59 PM
hs 81 problems
yes I tried it not mounted to anything and on my Corona....
crazhorse 07-17-2003 05:03 PM
hs 81 problems
when it moves past 90 it goes to the end of the range of motion but it doesnt seem to return to the same center point as when the stick is moved in the opposite direction.
