Savage spur gear
CA
Savage spur gear
Ok Ihave a savage 4.6 Ihave only ran about 10 tanks through it but anyways Ichewed my spur gear up pretty bad the factory didnt set the mesh right Ithink. So anyways Ihave been trying to get the mesh just right with the new gear and Ihave been having a really hard time. Ihave been using the paper method and the way Ihave it set right now the paper comes out looking like a acordion but there are no black teeth marks is this good? A lot of the videos Ihave seen say you should see the black teeth marks on it ? Anyways Ihave been having a real hard time with it when Ifirst put it on and ran it it started to chew it up again so Istopped in till Iget it right someone please help.
RE: Savage spur gear
Forget the paper method and do it by feel. Here is how. The most important thing is that both gears are straight (parallel). Slide motor up to the clutch bell til its meshed snugly. Then snug up motor. Turn spur gear andit willfeels tight and crunchy; thats to tight. Then back off motor just atiny tiny hair then tightened motor screws. Turn again. It should now be smooth no crunchiness. Mainly what i feel for is just a very very small tick of movement of the spur gear when i hold the clutch bell tightly with my hand. Just a very,very smalltick of movement. Then spin spur gear it should smooth and haveno binds or crunchy noise or feel. Its gonna wear in some. After one good run check again. It will now be super smooth and still have that tiny tick of movement.
RB
RB
NS, CANADA
ORIGINAL: RazurBlackz
Forget the paper method and do it by feel. Here is how. The most important thing is that both gears are straight (parallel). Slide motor up to the clutch bell til its meshed snugly. Then snug up motor. Turn spur gear and it will feels tight and crunchy; thats to tight. Then back off motor just a tiny tiny hair then tightened motor screws. Turn again. It should now be smooth no crunchiness. Mainly what i feel for is just a very very small tick of movement of the spur gear when i hold the clutch bell tightly with my hand. Just a very,very small tick of movement. Then spin spur gear it should smooth and have no binds or crunchy noise or feel. Its gonna wear in some. After one good run check again. It will now be super smooth and still have that tiny tick of movement.
RB
RB
Doing this makes the whole process quicker and easier. If you leave the screws loose, the mesh will change as you tighten them up, so leave them slightly snug and use the screwdriver until the adjustment is made, then tighten down.
I figured loosing meant just loose, I didn't feel explaining that detail was necessary. I explained the important stuff. How did go 209mark123????????
RB
RB
esavagenoobie We don't care about how you set up electric, Does it sound like we are talking about electric duh!.....HERE's Your SIGN..stay in your lazy boy forums.
RB
RB
CA
I did what u guys suggested I ran about 1 1/2 tanks through it today I see some very small black flakes comein from what im guessing is the spur gear is this normal there isnt a lot of play with the spur gear when I hold the clutch bell but Im not sure I hate to rip up another spur gear even though I have another one but still Im thinkin about goin to a steel spur gear.
OH
ORIGINAL: esavagenoobie
Setting the gear mesh on nitro motors, something i never understood how to do LOL... Electric is easy, you adjust 2 screws
It's really not that hard, dude.
ThunderbirdJunkie sets his mesh by feel with his 1/10 2w electrics as he does his 1/8 4w nitros. If you honestly think FOUR WHOLE SCREWS is too much, you should probably have stuck with this:
OH
ORIGINAL: 209mark123
209mark123 Did you make sure the gears are perfectly parallel with each other, like I said. Also, did you hold the clutch bell real tight with your
hand and feel ever so slight movement that that spur gear should have? After doing this does the the spur spin smoothly with no binds. If so,
you got it set right, Be sure to use tiny split lock washers and (blue)loctite on all motor mount screws.
RB
CA
Yeah they look paralell to me Iam going to pull it out again today and see whats going on when Ihold the clutch bell there is a slight tick when Imove the spur gear back and fourth.
209mark123 The spur is good though, zero signs of wear?? Just replace the the clutch shoes then,
likeThunderbirdJunkie said. That should get you fixed up.Also,Did youvisuallyinspect the
clutch bell for nicks in the metal teeth?, maybe a rock got in the
first time when you ate the first spur gear.
RB
RB
CA
Allright no there is some teeth marks on the spur gear but I think that was from when I first put it on I am keeping an eye on it. I am thinking about ordering the aluminum clutch is that a good one?
ORIGINAL: ThunderbirdJunkie
ThunderbirdJunkie does it exactly the same on his electrics as he does on his nitros. The only difference is there are 4 WHOLE SCREWS instead of two.
209mark123 Just stay with the stock parts dude,they are cheaper and they work just fine. You have already passed gear messing 101 with an A+.The only that is not bone stock on my Savage X 4.6 RTR is a HPI chrome pipe and bullet proof front and rear differentials. I run a medium range glow plug and Byrons gen2 20 % nitro and she run 48-49 mph everyday. I have replaced one rotostart one-way bearing,a couple shock parts, one glow plug (my fault) and one spur gear only because the engine mount screws came loose. BlueLOCTITE everything!! Rock and Roll.
RB
KS
A lot of spur gear failures are from clutch bell bearing failures. Keep an eye on those... Along the same lines, I think a lot of clutch bearing failures come from spur gears being too tight. Glen
CA
Thanks guys I picked up a racing cluutch bell for cheap on ebay and a HPI steel spur gear for a quarter of what they normally cost so just to see what all the hype is about the thing is I had to match my spur gear teeth to my clutch bell my ration will be 15/49 think thats ok I called HPI and they said it should be allright.
KS
If you are running short tires, like 5.5" or less, that will be a pretty low gear ratio. You will have lots of power, but not much speed. Great for short tracks, jumps, deep grass, rough country etc... Glen
ON, CANADA
ORIGINAL: Argess
There's a lot to be said for sticking with the stock parts:
