Flux pinion gear set screw backing out help.
VA
I am a new Flux HP owner. The first thing I did was add blue locktite to the set screw on the pinion gear. After four short runs, the set screw as backed out enough to allow the pinion gear to spin freely. What else can I do other then adding red locktite? I do not want to add red locktite, I am affraid i will never be able to remove the set screw.
RE: Flux pinion gear set screw backing out help.
lol ad a dot of red lock not over kill and u should be good
or if u have room on the screw to add another small nut, put a nut on it and ur good to go
VA
When you say small cut, could you give me more details, im not quit sure how to go about doing this.
Clean the blue loctite off and use red loctite, it WILL be fine and can be removed later on. If necassary, just heat it with a lighter
ORIGINAL: JesseJames
lol i mean nut not cut lol
ORIGINAL: Brainanator
I've never had a problem running blue locktite. But I crank down on the sun of a gun hard when I tighten it up.
I apply a large amount of the blue loctite it till it actually drips out of the front of the pinion though. Last time I took a pinion off I needed a hammer to tap it a few times to break the seal after I had the grub screw completely removed
