Flux HP vs 2350
APART from the esc and motor, what EXACTLY are the other differences between the HP and the 2350, if any at all?
New question... I understand the MMP esc of the 2350 is fine with 6s, just the 2350 motor is not. Therefore am I correct in thinking I need only to change the motor to the tork 2200 and I have a 6s capable truck?
Anyone know if I can simply bolt the Tork motor into the Qbase and run 6s? According to what I've read it should be that simple. Though I have seen one source that says that the speed control should not be used with 6s in 1/8th vehicles, only 1/10th. Since there are 1/10th vehicles approaching the weight of the savage, I'm assuming its safe to ignore this warning provided you have the right motor and gearing. I'll probably drop it down a couple of teeth to the 18 when I go 6s anyway.
PS. That thread is awful, it was when I first read it days ago. Not helpful to anyone. The first poster guessed (sorry syco, but ya did), the second poster sent the member to HPI's website, which doesn't really have all the info it should. The 4th post is hearsay from another forum and is dubious information, let alone off topic. The rest of the thread goes on about how great Castle are. :/ Shortly after that everyone starts posting why they bought one and not the other and patting each other on the back. I positively encourage the next person who wants the answer to this question to start a new topic.
For ref:
HP has MMM based ESC and a good quality 2200 motor, 2350 has MMP based ESC (still 6S capable, but dubious in 1/8th monster trucks, not recommended apparently) and a lower quality but still good 2350 motor which can only take 4s.
HP has 'super' high torque steering servo (still not good enough, but a worthy attempt I suppose for an RTR), 2350 does not.
HP has 2.4Ghz radio, 2350 does not (usually, there seem to be some mix n matchers around).
HP has classic Red body, 2350 has Blue
Both have Bullitproof diff uprade
Still looking for a definitive answer to my current question though. Will the Qbase (MMP) handle the TORK 2200 motor on 6s in a stock geared savage?
http://www.rc-monster.com/forum/showthread.php?t=27745
What is it that limits the 2350 to just 4S then - MMP is 6S rated??
1) The ESC will handle 6 cells, but it's not recommended in the Savage with the 2350 motor (inferring that the weak point is the motor, and if the motor were changed, maybe everything would be fine)
2) The ESC will handle 6 cells, but it's not recommended with ANY motor (inferring that the ESC is the problem because of the weight of the Savage, and any motor capable of utilising 6s power will draw too much current through the system) in a 1/8th monster truck.
Which leaves me with; if 1, I will buy a Tork 2200 motor and start running 6 cells. If 2, I will buy a blur and tork 2200 at some point, and transplant the 2350 and qbase into my next 1/8th brushless.
PS. Also relelvant that it is marketed as a 1/10th product on their site. I'm guessing it melts with 6S in a 1/8th monster, regardless what motor it has on it.
http://cgi.ebay.co.uk/Kershaw-design...item4159fb0a98
price seems reasonable.
I have both and have to say that the 6s 2200 is your best choice. It is so powerful that you only need to use ¼ of the trigger most of the time. With this you can easily get 40+ minutes of use out of it. The only bad thing about using 6s is you are going to break it much faster. Remember to buy spare parts to repair the diffs. LOL!
I would never try the 2350 with 6s. Unless you are going to change out the motor but that would cost $ and time when you could’ve spent another $100 for the HPI104240.
Good Luck!
I've been reading up on this a bit and am considering dropping one into my Flux.
da blur esc cant evn handle 6s.
no way in hell da q base can.
spoken frum sum1 whos blur caught on fire usin 6s
Stop trolling with terrible grammar
<style type=''text/css''>@font-face { font-family: ''Arial'';}@font-face { font-family: ''*S 明朝'';}@font-face { font-family: ''Cambria Math'';}@font-face { font-family: ''Cambria'';}p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: Cambria; }.MsoChpDefault { font-family: Cambria; }div.WordSection1 { page: WordSection1; }</style>
Good Luck!
Despite not agreeing with his reasoning, I have to concur with xerxes, and I would expect a meltdown if not quickly, then eventually. And that would then defeat the object of both routes. I wouldn't have a spare esc/motor combo for a 1/8th buggy which I will definitely do after the Savage, and I'd still have to buy the blur and tork.
I tried to research information to answer your question but I couldn't find anything absolute. So, in the end if you end up with a 2350 and eventually upgrade the brushless system leaving the stock 2350 Qbase system unused, does a Tekin RX8 system as the upgrade sound alluring? http://www.ckrccrawlers.com/tt2320-t...kv-p-3361.html
I think what I'm going to do though, is hold out for an HP, and probably buy the RX8 and a really hot motor for the buggy.
He has experiences with the truck which are valid. Maybe some of his problems were his fault, maybe not, it doesn't matter, all experience is relevant in a context.
