Flux is locked up?
IL
Flux is locked up?
Ok so the other day i was driving my flux and all the sudden it locked up! I only got to drive it for about 5 minutes. That was after i replaced the pinion gear. The pinion and spur gear look to be in good shape, but when i give it gas it just starts clicking. The pinion and spur gear are moving against each other, but not much. What is my problem?
Please Help!
Thanks guys!
Please Help!
Thanks guys!
IL
RE: Flux is locked up?
No, they move properly. It's just when i give it throttle it acts like it is locked up. I'm not sure what it is because this has never happened to me before.
IL
leme ax u sumtn rite quik.
wen u giv it gas it jus stutters & cliks rite?
giv it gas & wen it starts stutterin & clickin, manualy push da truk by hand.
does it take off & drive normally?
IL
ORIGINAL: xerxes
I did just what you said and it did not take off and drive normally. I gave it throttle and pushed it forward manually and it just made that weird noise and didn't go anywhere. It's like the motor is hung up or something like that.
IL
ORIGINAL: xerxes
hmm. wit da power off, can u roll it by hand freely?
BC, CANADA
ORIGINAL: xerxes
well if ur posetiv its da motor, tak it apart. unless its da alfastar. i coodnt get dat 1 apart, evn aftr gettn da endbell screws out
Also have you tried taking the motor out of the truck and turning the spur gear? Does it turn smoothly?
Also check the motor outside of the truck. Just try spinning the shaft first and see if it turns easily. It should help you figure out if its the transmission or the motor.
ORIGINAL: parry13
You mentioned that the differentials are functioning because you can turn one wheel and the other side turns the opposite direction. But, that really only means the spider gears are still intact. What if the ring and pinon gears are crunched? You'll have to push the truck to see if anything binds or locks up.
VT
as i'm sure you noticed the motor doesn't spin super smoothly on it's own due to the strength of the magnets so it will feel notchy... when you pull the motor out, but it should run just fine, and shouldn't take much to push it and get it going...
the lug
the lug
IL
It's like the clutch is locked up or something because the spur gear wont spin. And obviously do to that, the motor and pinion wont spin.
MT
i say a tranny gear....if you think the clutch is locked then you obviously don't know what's going on. There is nothing wrong with that though, not trying to sound degrading. You just need to start tearing into stuff find out where the problem is.
IL
ORIGINAL: Brainanator
Thanks for the help guys!
Look in the transmission:
Start by removing the 4 screws that secure the grab handle to the chassis. Pay attention to where the screws were removed from because 1 of them is shorter than the others.
Remove the spur gear guard which is retained by 1 screw.
Remove the 3 screws that point down located at the top of the transmission.
Remove the top half of the transmission; the top shaft (spur gear shaft) will come out with it.
From here you can inspect the internal gears and see if anything is broken.
Good luck!
Good luck!
MT
ORIGINAL: savycharlie
Ya you're right! I'm only 15 and i'm still learning. I'm getting better at working on them though, i just need to do it more.
Also, take a look in your manual, read it through if you haven't yet, even if it's boring. The manual goes through a lot of the maintenance steps for the savage flux, with decent illustrations. It also has the most valuable tool, the Exploded View. Which tells you where each part goes, and the part number so you have order the exact right part.
Good luck! and have fun working on it!
IL
ORIGINAL: BKoz559
Good luck!
Good luck!
Sidenote: i can turn the pinion gear but it takes a decent amount of force and it isn't smooth at all.
Thanks for the help everyone!
savycharlie
MT
pinion gear (on the motor) should feel very notchy. That is the magnets and windings and and what not. As long as there are no grinding sounds or something then your motor is fine. Notchy and smooth is good, notchy and gritty is bad.
With the tranny being fine, next culprit could be drive shafts (dogbones and cups) or the diff ring and pinion. The manual shows you have to access your differentials pretty quick and easily. Since the diffs unload easy when you spin the wheels, you're examining the outside of the diff.
Actually....now that you got the top of the tranny off, how does the feel? still locked up?
IL
Ya with the tranny cover off i can push the truck forward with no problems. Since the pinion gear is meshed with the spur gear (and the pinion gear wouldn't move without me manually pushing it with the spur gear off i can push it and everything looks, and feels fine.) I plugged the batteries in and tried it with the spur gear out (transmission) and the motor shaft/pinion gear moved just fine. Like you said it wouldn't push very easily manually because of the magnets.
