HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
diff options
Old 05-30-2012 | 11:38 PM
the nitro way's Avatar
Default diff options
well guys what can i do with my savage the 457 is getting terminal with the diffs my front diff is dying and its "bullet prooff" any suggestions will flux gears work if so i will kill the 457 and get me a ported sh28 p8 fully modded to bash
Old 05-31-2012 | 12:37 AM
Foxy's Avatar
Default RE: diff options
High power will eventually kill any RC. Do you not feel you got your money's worth out of the stocker? There are very few diffs that are stronger than the bulletproof ones (at least the ring and pinion). Some people change the internal gears, but the ring and pinions are actually fairly 'bulletproof'. 6S electric power destroyed my Mugen truggy front diff in pretty short order, and that's one of the few diffs that I would say is probably stronger than the HPI BP ones. 6S is a bit more power than your nitro engine, but the effect is the same, under high power front diffs will suffer first. Also, did you shim them well (and I mean really painstakingly well), the Savage diffs are VERY dependant on proper shimming to be reliable.
Old 05-31-2012 | 01:51 AM
Here is your answer, its extremely strong
http://www.savage-central.com/module...wtopic&t=94304
Also note that when your jumping which im sure you are if your breaking a BP pinion, dont land with the throttle mashed down. Thats how they break
The 2011 savage X bp diff is very strong as well. My ERCM picco gives those ring and pinions hell. I also run 6s on my flux with zero issues now.
Old 05-31-2012 | 02:09 AM
Foxy's Avatar
Nice write up, why though did you not use the HPI metal diff case?
Old 05-31-2012 | 11:07 AM
thx for help il take this into consideration
Old 05-31-2012 | 01:59 PM
because the vorza cup uses an 8mm bearing which is thicker and stronger than the 10mm bearing which always fails. This setup will allow you to use the same bearings thru out the entire truck. I have over 15 packs thru my XL Flux with zero wear to my bearings. I recently opened the diff up and added more oil then dropped it back in. Keep in mind I run 6s and beat the crap out of my trucks. This mod has been battle tested and works.
