For all Savage SS and .25 owners
Well I think HPI needs to change the RTR from Ready to Run to Remove Thread Lock Replace. everyone should be sure to check their back plate also my .25 didnt come with all the pieces for the clutch bell I was missing the outside bearing spacer and screw
so just another thing for everyone to check
Aron
Aron
RE: For all Savage SS and .25 owners
yep, the backplates on the 25's on the ss's were not thread locked, or it was a hit or miss kind of deal, mine backed off as well. never thought of it as i built the kit.
Yeah, mine was too way back when.
But o' threadlock quickly sorts it out though
No biggie....
Just make sure y'all catch it before you loose the spring / pin that attaches the backplate to your conrod
No biggie....
The backplate is located on the back of the engine. Take the pull start off and make sure the four screws on the plate under it are tight.
Yeah I had to do the same for my Ofna Force .25.. But now she's running like a weapon. Mind you I should add that the savage is actually a paperweight at the moment, as the terra crusher is getting a fair bit of attention.. I'll start a post with a pic.
Ted
Ted
You could've just copied the details here for everyone
Anyone with an ss will be familiar with the dismantling of the car anyway, but all you have to do is pop out the four screws holding on the enging, remove the engine, pop off your pull/rotostart from the back of the block and then examine the backplate (the plate underneat the pull/rotostart).
You should remove the four screws in that, stick some threadlock in the holes, and then put the four screws back in tight - this plate should end up flush with your engine block, with no gap between the two.
If you find the plate is loose, you might wanna take it off completely and make sure you haven't lose the pin/spring connecting it to your conrod first. You really don't want the engine to turn over if they come loose - they'd play havoc with your innards
Thanks guys, I got savage.25 coming tomorrow. The first thing I do will be to take off the roto start & check the backing plate. Is there anything else to look for? any way thanks again,I cant wait to get the mill broke in this weekend to see how it runs.
nitro-Al, I have not found any other problems with mine so far. You might just want to do the diff mod when you get it. I couldnt wait to take mine all apart so the mod gave me a good excuss. For some reason I like haven my truck in about 100 peices all over the table more than I like it in one piece!
NY
ORIGINAL: nitro-Al
NC
As long as you guys are threadlocking the backplate screws, go ahead and seal the backplate with some high temp RTV sealant. Do the carb throat too. My NS.25 had a ton of airleaks and it ran like a dream after I sealed it all up.
