engine seized (help)
hi
iv had a gallon through my 21bb engine and it has seized up completly i cant pull the pull start and the flywheel wont move. before it seized up it seemed 2 be running perfect until it cut out and thats when it seized[&:].
please help
wot could be wrong?
thanx
please help
wot could be wrong?
thanx
its ok iv sorted it i tuck it out my truck and noticed that ther was a stone stopping the flywheel from moving so iv clean my truck put it back it and its fine
ON, CANADA
Ok, glad things worked out. If I can assume the time stamp is right on your post, it took you 2 hrs to figure this one out on your own. Your an absolute genius. You should be proud of yourself dude.
thanx. yeah it turned out to be somthing as little as a stone all that worring that i would have to do a rebuild for nothing.
