Spider gear mod, recommendations?
TN
RE: Spider gear mod, recommendations?
use some oil and you want thinner oil in the front. that means the higher the number on the oil, the thinner it is.
ex (what i use): 7000 in the front, 5000 in the rear
Depends how you want the diffs to react, if you put in a thinner oil (1000wt) the diffs will work 'as they should', if you put in a really thick oil (like 100,000 wt) the diffs will work more like they have been locked.
Personally I have 30,000wt in the front ( keeps the power down when the beast is cornering hard) and 10,000wt in the rear.
