im confused?!?!?!?
KS
im confused?!?!?!?
i get er runnin and she sounds a little boggy so i shut her off and tune the stock settings(not break in settings)and i noticed the low speed needle was way out.so i screwed it back in and try to start the engine plugging exhaust and all that stuff and she wont crank over. once i get her started she is screaming hard at idle?!?!? and after 1/5 turn on the idle she shuts off. then ten minutes later we start it up again and she is still screaming hard and the idle is set at 2mm. and look down in the cooling head she is spitting fuel out of the glow plug. change plug and it is still the same screaming hard at idle. i retuned the carb and still same results. WTH is goin on here?!?!?
KS
RE: im confused?!?!?!?
ok i started it again with your tunings and it sounded good for the first 3 minutes and it started wining again so just out of stupid mind i leaned the LSN out until it just shut off. then i realized it was extremely hot and it took a long time to cool off. was this cause it was 100 degrees outside or the tuning.
NY
Sounds like you are running way too lean. start @ the fastory break in settings. Does your truck run on those ( even if it runs super slow) Then without shutting your engine off, lean the low needle 1/2 turn. Then start leaning the high very very slowly and while the truck is running. take test runs to see changes in performance. A properly tuned engine will idle steadily. If this does not work I would start checking for air leaks in the carb and back plate. What kind of engine is it anyway?
KS
i started it again and it did that wine thing again as soon as it heated up. did all that tuning thing (stock, w/e) and it didnt run long enough to tune. i think either the piston is shot or the carb is screwed. im going to my LHS tomorrow and ill have them look at it. thanks for all your help.
ORIGINAL: Viper_GTS-R
When you tune these engines you will get the best results by tuning the hsn first. Once you get the fuel delivery correct and performance seems to be decent then and only then should you adjust the lsn. The lsn is primarily used for throttle response or acceleration. The idle screw, if you engine is equipped, should only be adjusted after the hsn and lsn are set ideally. Trying to adjust the idle when the engine is still not tuned correctly can throw off the tuning completely.
I hope this helps.
Aloha
OW MAN IF IT dosent start at 100 F i wont start mine when i get it for the whole summer at night our temp. is 108F man that will be bad.
Bader
KUWAIT
Bader
KUWAIT
