PICS OF YOUR TRASHED SHELLS
stole this idea from another forum! lets try it here
weve all seen them nice and clean, now lets see them trashed!
ill start it off
(if you notice the back cut out thats wher my crap rc solutions roll cage went)
ill start it off
KS
RE: PICS OF YOUR TRASHED SHELLS
well not nessesarily easier just its not a hassle to know where they areand not loose them all the time. plus if they fall out they are stoll on the "clip savers" so all you do is just take em out and drop them and they are on your body already.
don't use pliers. there used to be a thread somewhere about how to make a nifty handle for removing body clips.
basically, run a zip tie through a piece of fuel tubing, then around the back end of the clip and *back into the fuel tubing.* Snug it up, zip it, clip it and you're set.
MT
easy fix for that.. is dont use the shell.. i dont see why anyone would run it with it on for bashing... it runs cooler w/o it
ORIGINAL: ahab
Sari,
does that zip tie between the body clips make them any easier to get off? I am using a small set of pliers ATm.
Sari,
thats y i did em
wow, it turns out I am psychic... [&:] Sari..Viper...whats the Difference>? Oops....
thanks guys, I think I will try that with the fuel tube and the zip tie....
As for bashing with no body... I like it to look like a truck... otherwise I would bash with my lawnmower....
those zip tie clips are easier to pull off. i also did that. and i did a bigger one on the fuel tank too. except if your truck is light the fuel tank one wont work cause the car lifts up.
